- lun. 12 févr. 2007 21:20
#58397
J'ai fait une courte recherche, et je croit que personne n'a posté sa!
La question qui tue....
D'où vient votre nick-name???
Moi c'est le nom d'un trois-roues
Honda ATC350X 1986
Frame number JH3TE0806GM100001~
Engine number TE08E-5100001~
Engine type 4 stroke, Oil cooler
Displacement 350.4 cc
Bore x Stroke 81 x 68 mm
Compression ratio 8.5 to 1
Compression 178 psi
Transmission speeds 6 speed
Clutch Type Manual
Oil Capacity 2.43 Qt
Carburetion 34mm Keihin
Starting system Kickstart
Fuel capacity 2.6 gal with .4 gal reserve
Wheelbase 50.0 in.
Overall Length 74.4 in.
Overall Width 43.9 in.
Ground Clearance 4.7 in.
Seat height 27.8 in.
Front tire 23.5 x 8 x 11
Rear tires 22 x 10 x 9
Front suspension 35mm telescopic Forks, 8.0in Travel
Rear suspension Mono shock, 7.6in Travel
Front brake Hydraulic disk
Rear brake Hydraulic disk
Final drive Chain
Dry weight 320 lbs
Approx. retail new $2,298.00
Ça c'est ma machine de rêve!!!
Vous-autres asteure!?!?
Honda ATC350X 1986
Compression 178 psi
Clutch Type Manual
Wheelbase 50.0 in.
Final drive Chain
Dry weight 320 lbs
Mack SuperLiner 1987, Cat 500HP...Que de beau souvenirs...I'm A Road Hammer!!!
