By Nattefrost
#61227
Je viens de remarquer ca en lisant sur le site de l'Ontario. On peut splitter les heures de couchette...
En deux périodes, une période minimale de 2 heures et elles doivent totaliser 10 heures.
Alors exemple 2/8 3/7 4/6 5/5
Québec s'enligne pour accepter les splits des heures ?
By BB007
#61247
De mémoire, car je n'ai pas mon document de l'ASTE, oui c'est possible mais non recommandé.
#61290
Impossible!!!!
Le seule split possible est 8/2 est dans l'ordre s'il vous plait.
Autre chose, vous pouvez, si vous êtes un team, faire un split 4 / 4 / 2
C'est tout.... aucun autre split possible!
By BB007
#61302
D'oh!
Jos: 747
BB007: 1
Tu prends ta vengeance? :wink:
By Nattefrost
#61318
Splitting off-duty time
11. (1) A driver may meet the off-duty time requirement of section 9 in a sequence of sleeper berth periods under subsection (2) or (3) until the sequence of sleeper berth periods ends with a period of at least eight consecutive hours of off-duty time, if all the sleeper berth periods in the sequence meet the requirements of subsection (2) or (3), as the case may be. O. Reg. 555/06, s. 11 (1).
(2) A driver who is driving a commercial motor vehicle fitted with a sleeper berth may meet the mandatory off-duty time requirement of section 9 by accumulating off-duty time in no more than two periods where,
(a) neither period of off-duty time is less than two hours;
(b) the total of the two periods of off-duty time is at least 10 hours;
(c) the off-duty time is spent resting in the sleeper berth; and
(d) the driver does not drive again when,
(i) the total of the driving times before and after each sleeper berth period in a sequence referred to in subsection (1) exceeds 13 hours,
(ii) the total of the on-duty times before and after each sleeper berth period in a sequence referred to in subsection (1) exceeds 14 hours, and
(iii) the total of the elapsed times before and after each sleeper berth period in a sequence referred to in subsection (1) exceeds 16 hours. O. Reg. 555/06, s. 11 (2).
Mon anglais est peut-etre moche, mais je comprends pas encore sinon :/
By Nattefrost
#61323
ok cest beau je viens de relire en me concentrant plus :twisted:
#61427
Nattefrost a écrit :Splitting off-duty time
Juste pour être sure que tout le monde à bien compris! La pire erreur est celle qui n'est pas admise :wink:
Attend quand même que je t'attrape espèce de jeunes fous :wink:
