#236612
voici un petit gadget qui peut vous aider
http://www.thinkgeek.com/interests/moms/b8ea/
ndoor air can get especially dry in the cool months when heating systems are blowing and wicking moisture from the air. Most people come up with a practical solution for at home - boiling water on the stove, whistling tea-kettle, or R2D2-sized humidifiers - but this can get a little tricky at the office or when traveling.
The office-administrator won't let you boil water at your desk, and a big water-tank can be inconveniently huge to lug around, so what can you do? Our personal humidifier's compact, lightweight design that fits easily into luggage or a carry-on bag provides a convenient way to add humidity to the air wherever you are. To use, simply plug it in, turn a regular-size bottle of drinking water (sold separately) upside down into the top of the unit, and turn the knob to adjust the humidity level from low to high.
Using ultrasonic technology, the humidifier produces a cool mist (120cc per hour) while offering quiet operation and low power consumption. Two different-sized bottle adapters and a UL-approved AC adapter make it easy to use almost anywhere. The 15-watt humidifier measures 4 by 2-1/2 by 3 inches. Go from "dry as a desert" to "breathing easy" in no time.
By eljeune
#236692
Le tata a écrit :des tapis plein de gadoue ca doit faire aussi :mrgreen:
Pour ceux qui débarque souvent sa doit faire la job certain!
El-Jeune :wink:
Əməliyyat limitləri
snow rider is a solid time-killer, but the speed r[…]
