- jeu. 13 août 2026 01:12
#337011
Preparing for a raid in ARC Raiders is easier when you stop treating every deployment as a copy of the last one. The right weapons and utility depend on what you want to accomplish, how much risk you can accept, and what the map is likely to throw at you. The same approach also helps when collecting ARC Raiders BluePrints, because a successful run is not always the one with the highest kill count.
ARC Raiders BluePrints can become part of a longer progression plan, but getting them safely home requires practical preparation. A solo scavenging trip, a heavy ARC hunt, and a PvP-focused extraction all demand different equipment. Instead of chasing one rigid meta build, it makes more sense to create several flexible setups that can be adjusted before each deployment.
Start With The Goal
The easiest way to build a flexible loadout is to begin with the purpose of the raid. Think about three things: your goal, your restrictions, and the map.
If you are mainly collecting resources, backpack capacity and safe extraction tools should matter more than maximum damage. If you are hunting large machines, you need weapons and ammunition capable of handling heavy armor. A PvP run has different requirements again, with more emphasis on burst damage, protection, grenades, and recovery tools.
Your available resources should also influence the decision. Bringing your most expensive equipment into every ordinary raid can make mistakes unnecessarily painful. Sometimes a cheaper setup is actually better because it allows you to take more calculated risks.
Solo Scavenge Setup
For solo resource gathering, a Kettle Level 3 or Ferro paired with a Stitcher offers a practical combination. The Kettle or Ferro can deal with targets at range, while the Stitcher gives you an option when enemies close the distance.
A Looting Mk 2 Augment and Light Shield fit this role particularly well. The extra backpack capacity gives you more room for resources, while the lighter equipment keeps the setup relatively easy to manage.
Your quick-use items should focus on survival. Herbal Bandages and Shield Rechargers provide basic recovery, while Adrenaline Shots can help when you need to escape a bad position. A Raider Hatch Key is also useful because it gives you another way to think about extraction rather than forcing every fight.
Heavy ARC Hunting
A raid built around Matriarchs, Queens, or Bastions needs more serious firepower. A Pharaoh 1 with an Anvil or Osprey gives you a strong foundation for dealing with heavily armored machines.
The Tactical Mk 2 Augment and Medium Shield combination adds another layer of flexibility. When the shield breaks, the automatic smoke grenade can create enough breathing room to reload or move away from danger.
Trailblazer Gas Grenades are also valuable in this situation. Carrying several stacks gives you sustained damage against ground-based ARC enemies without requiring you to stand directly in front of them for the entire fight.
PvP And Squad Preparation
When you expect crowded hotspots or contested extraction areas, combat efficiency becomes more important than storage space. An Arpeggio paired with an Il Toro using Choke 3 can perform well in close-to-medium-range encounters. A Venator is another option for players who prefer strong burst damage.
Combat Mk 3 with a Medium or Heavy Shield makes sense for aggressive engagements. Heavy Fuse Grenades or Trigger Grenades can push opponents away from cover, while Smoke Grenades can protect revives and emergency healing.
Squads should also consider Defibrillators or Snapbooks. Keeping teammates active can be more valuable than carrying another small stack of loot, particularly when a fight becomes chaotic.
Organize Before Deploying
Good preparation also starts inside your stash. The Unsorted tab can be used to organize rough loadout presets. Place an augment, compatible shield, weapons, and ammunition together so you can rebuild a familiar setup quickly.
Resource tracking is another useful habit. If you are working toward a Workshop upgrade, track the required materials before entering the map. This makes it easier to recognize which items are worth keeping instead of filling your stash with resources you do not currently need.
Free Loadouts should not be ignored either. They are useful when credits are low, when learning a new map condition, or when you simply want to test a route without risking expensive equipment.
Match Gear To The Raid
Flexible preparation is ultimately about matching your equipment to the job. A scavenging run should prioritize storage, mobility, healing, and extraction options. An ARC hunting run should sacrifice some carrying efficiency for stronger weapons and specialized utility. A PvP setup needs protection and tools that help control fights.
That same mindset is useful when deciding whether to buy ARC Raiders Bp for a particular progression goal. The important part is not simply owning more gear, but making sure what you bring actually supports the raid you intend to play.
The more familiar you become with your preferred loadout patterns, the easier it becomes to adjust them without wasting resources. Keeping the right ARC Raiders Materials in your stash, tracking upgrades, and maintaining a few reliable setups can make preparation faster and every successful extraction more meaningful.
Start With The Goal
Solo Scavenge Setup
Heavy ARC Hunting
