By IronWolf2
#336797
Slapping a shiny new attachment onto your weapon in an extraction shooter usually triggers an immediate dopamine hit. But over in r/ArcRaiders, the Epic-tier Lightweight Stock has sparked more intense spreadsheet math and heated comment threads than almost any other item.
It is a high-mobility modification designed for players who love an aggressive, fast-paced playstyle. Yet, for months, the community has argued over whether it is actually a god-tier attachment or a bugged waste of an inventory slot.
Let's dive into the hard numbers, the weird mechanics, and how this piece of gear actually works in the field.
The Core Stats
According to community database tracking on sites like Warzone Meta, the Lightweight Stock operates on a high-risk, high-reward framework. It provides massive, game-changing handling boosts, but the trade-off is a heavy penalty to your weapon control:
+200% Aim Down Sights (ADS) Speed
+30% Equip & Unequip Speed (for significantly quicker weapon swapping)
+50% Vertical Recoil & Recoil Recovery Time
On paper, a +200% boost to your ADS speed sounds like you should be snapping to your target instantly. But in practice, this specific stat caused massive confusion across Reddit, leading many players to claim the stock was straight-up broken.
How "ADS Speed" Actually Works (and the Bugs)
The main point of confusion stems from a classic gaming misconception. When players first equipped the stock, they ran into the firing range and noticed that the physical scope-in camera animation didn't actually move any faster. Threads quickly popped up with titles complaining that the "+200% increased ADS is a lie."
However, mechanical testing by r/ArcRaiders users revealed a different reality. In ARC Raiders, "ADS speed" doesn't actually speed up the visual camera animation. Instead, it dictates how fast your weapon's crosshair reticle tightens to maximum accuracy when you press the aim button.
Essentially, this mod transforms your gun into a "quick-scope" machine. You can pull the trigger and land a pinpoint, perfectly accurate shot before the scope animation even finishes displaying on your screen.
Visual Camera Animation (Standard Speed)
Reticle Accuracy Tightening (With Lightweight Stock)
[==========] -> Maximum Accuracy Achieved Early!
The Movement Bug & The Osprey Fix
While the underlying mechanic works, the stock hasn't been without its flaws. A notorious movement bug, heavily documented on the subreddits, historically prevented the ADS buff from applying if you tried to aim while moving. If you were strafing or sprinting into a slide, the 200% buff dropped to 0%, only registering properly if your feet were firmly planted on the ground.
Furthermore, the attachment was completely broken on the Osprey sniper rifle for a long time, providing zero benefit to the weapon's sluggish handling. Fortunately, patches in May 2026 finally deployed an official fix for the Osprey. This fix has completely revived the weapon, turning the Osprey and Lightweight Stock combo into one of the most popular "huge ADS improvement" setups in the current meta.
Best Weapon Synergy
Because a +50% vertical recoil penalty will turn any automatic weapon into an uncontrollable hose, players explicitly warn against using this stock on high-recoil, spam-fire guns like the Vulcano. If you try it, your reticle will be staring at the sky before you finish half a magazine. Instead, the community recommends pairing it with specific archetypes:
1. High-Damage Single-Shot Weapons (Osprey & Ferro IV)
These are perfect matches. Because you are chambering a single round between shots, you completely bypass the +50% recoil penalty. By the time you are ready to fire your next shot, the gun has naturally settled. You get all of the instantaneous pinpoint accuracy with none of the visual kickback.
2. Panic & Peek-Shooting Weapons (Renegade & Hullcracker)
The +30% equip and unequip speed shines here. It allows you to run a highly mobile setup, swap to your secondary instantly when caught off guard, fire an incredibly accurate shot, and swap back or sprint away without getting bogged down by slow weapon-handling animations.
Where to Find the Blueprint
Getting your hands on this Epic blueprint requires some target-farming, as it is a highly sought-after rare drop.
If you are tired of RNG or want to bypass the grinding loop to optimize your build quickly, third-party marketplaces like U4N offer an alternative route to pick up an arc raiders crafting blueprints discount, allowing you to secure the necessary gear without spending dozens of hours hunting specific drop rates.
For those looking to find it out in the world, players over at r/ArcRaidersGuides report that the blueprint drops most reliably under very specific map and weather conditions:
Location Specific Area Required Map/Weather Condition
Container Storage Inside the Breach Room 2X Map Conditions
Blue Gate Village Reinforced Reception Area Hurricane Weather
Buried City High-tier Loot Chests Cold Snap Conditions
If you are hunting it manually, make sure to check your map modifiers before deployment. Heading into Blue Gate Village during a Hurricane or hitting Container Storage during a 2X event will dramatically increase your chances of walking away with one of the most powerful—and heavily debated—handling modifications in the game.
I completely agree that online gaming is an incred[…]
Dark And Darker Gold is once again one of the ho[…]
MLB The Show 26 Stubs continues to dominate the […]
