By routier_suisse
#222593
je voudrai juste savoir une chose, au canada, l essence que vous avez (bronze) c est du sans plomb 95, 98? ou de l essence avec plomb.
merci de m eclairer ma lanterne car je regarde doucement pour faire quelque petit transformation sur mon brave saurer et j aimerai y mettre un petit groupe electrogene dessus. histoir de savoir si les carburant sont compatible ou pas.
By marcsrt-4
#222608
ne pas confondre les indices d'octanes en amerique avec ceux en europe ou ailleur dans le monde c'est pas calculer de la meme facon :wink:
In Europe 98-octane gasoline is common and in Japan even 100-octane is readily available at the pumps, but this octane nomenclature is misleading to Americans as foreign octane ratings are derived entirely differently from our own... So, like every other measurement system it seems that everyone else uses a different scale than we do, but unlike most other instances where we have had the good sense to create different units of measure in this case we all use the same name...
Japan and Europe use a system called RON or Research Octane Number to determine the octane rating of their gasoline, while stateside we use a system called AKI or Anti-Knock Index to determine gasoline's octane rating... Interestingly, to further complicate things it would seem that our own AKI system is actually derived from the average of the RON system and another more complicated system referred to as MON or Motor Octane Number... So, to recap our methodologies for measuring gasoline's octane rating are different, but share some common elements...
So, with the commonality of RON in mind a good rule of thumb is as follows, multiply the foreign RON Octane rating by 0.95 and you will have the US AKI equivalent.
( RON Octane Rating x 0.95 = AKI Octane Rating )
98 RON Octane x 0.95 = 93.1 AKI Octane (US measure)
100 RON Octane x 0.95 = 95 AKI Octane (US measure)
So, as you can see the 93 or 94 octane fuel we are all paying an arm and a leg for is actually quite comparable to the higher octane fuels found in Europe and Japan. The people whom have to worry about low octane rating are our friends out west in places like California that are subjected to substandard 91 octane.
91 AKI Octane (US measure) = 95.5 RON Octane
By marcsrt-4
#222610
[quote="routier_suisse"]je voudrai juste savoir une chose, au canada, l essence que vous avez (bronze) c est du sans plomb 95, 98? ou de l essence avec plomb.
quote]
les essences avec plomb sont tres tres limitees,elles sont reserver a l'aviation et aux catrburant de moteur de course et coute extremement chere,dans les stations services standard partout ailleur c'est des essences sans plomb.
By bobic
#222640
L'essence bronze ici au Canada est du sans-plomb de base de chez Shell environ 87% octance copain...
By routier_suisse
#222750
super, merci les amis.
il y a des suisses qui traverse actuelement le canada en Saurer 2DM avec une remorque inf 70 comme le miens sauf que la couleur de la cabine et bleu. au derniere nouvelle il sont en alaska actuelement. si vous le croiser donner un bon coup de corne.
je pense bien un jour faire la meme chose avec le miens... mais pas tout de suite lol.
quelque photo pour le reconnaitre.
