#336798
Farming materials in Arc Raiders can feel like a massive bottleneck, especially when you are trying to craft hard-hitting mid-tier weapons like the Torrente, Osprey, or Tempest. Among all the components you need to stockpile, Medium Gun Parts are easily one of the most vital. They weigh 0.4 kg each and hold a baseline recycle value of 700, making them highly valuable both for your armory and your stash budget.
If you want to stop guessing and start optimizing your extraction runs, you can reliably find and accumulate Medium Gun Parts using four distinct methods.
1. Purchase Directly from Celeste (The Zero-Risk Method)
The fastest and most consistent way to get your hands on these parts without risking your gear in a live drop is right from the lobby.
Navigate to your traders menu and visit Celeste, the seed trader in the colony. She sells them directly under the following conditions:
Daily Limit: Up to 3 Medium Gun Parts per day.
Cost: 15 Assorted Seeds per part.
If you match her daily restock, you can secure 21 parts a week just by trading in seeds you pull out of easy runs.
2. Recycle and Dismantle Your Surplus Guns
If your stash is getting cluttered with weapons you don't use, you are sitting on a goldmine of weapon components. Opening your inventory and choosing to recycle mid-tier firearms will instantly dismantle them into raw materials.
Dismantling weapons yields a reliable return:
2 Parts: Renegade I & II, Torrente I & II, Osprey II, Canto I & II, Venator I & II, and Tempest I & II.
3 Parts: Upgraded variants like the Canto III & IV, Renegade III & IV, Torrente III & IV, Osprey III & IV, and Venator IV.
4 Parts: High-tier versions like the Tempest III & IV.
Before you drop real cash on third-party sites like U4N, or find yourself asking is it safe to buy arc raiders items online, remember that the game provides plenty of legitimate ways to secure gear just by breaking down what you already own. Trading items via community marketplaces or third-party sellers can violate terms of service, so maximizing your in-game recycling loop is always the safest bet.
3. Map Hotspots and Targeting ARC Machines
When you are boots-on-the-ground, your drop location dictates your success rate. According to regional drop statistics, your time is best spent hitting specific high-tier zones:
Map Area Estimated Drop Share / Probability Focus Locations
Dam Battlegrounds ~40% Dam Control Tower, high-value weapon cases
The Spaceport ~20% Departure Building cabinets and drawers
Stella Montis ~15% Archives key room, locked rooms
Buried City ~15% Residential areas, lockers, supply crates
To maximize efficiency, target Yellow Zones (Medium loot value) and Red Zones (High loot value). Don't just search the weapon crates; search residential drawers, lockers, and supply drops. Additionally, keep an eye out for larger ARC machine variants like Bastions and Sentinels. Destroying them gives you a natural, built-in chance to salvage these parts straight from their wreckage.
4. Crafting via Blueprint (The Infinite Solution)
For a permanent, long-term solution, you need to find the Medium Gun Parts Blueprint. This Legendary-tier blueprint allows you to mass-produce the material right at your hideout workbench.
The Crafting Formula
Recipe: 4x Simple Gun Parts $\rightarrow$ 1x Medium Gun Part.
Workbench Requirement: You must upgrade your Refiner workbench to Level 2. This upgrade requires you to track down specific industrial loot, including toasters, fireball burners, and arc motion cores.
Hunting the Blueprint
Because the blueprint does not have a guaranteed quest reward or static spawn point, it relies entirely on RNG. Your best odds of finding it mean hitting high-value locked loot rooms that require specific keycards.
Run the Spaceport at night to hit the Departure Building, use keys to open the Archives key room on Stella Montis, or target Raider Caches during active map events. Once you find it, make sure to immediately slot it into your Safe Pocket. If you get wiped before extracting, losing a legendary blueprint like this will set your workshop progress back significantly.
Farming materials in Arc Raiders can feel like a m[…]
Slapping a shiny new attachment onto your weapon i[…]
From my experience, exploring better ways to prepa[…]
A Student’s Perspective on Digital Innovatio[…]
